IR3220 Drum Info
  • Digicomm
    • Sep 2010
    • 65
    IR3220 Drum Info
    Can i swap a partially used black drum unit (34%) used ,for a worn out one (174%).I also looked on E-Bay and they're selling a drum reset chip.Any info would be appreciated
  • charm5496
    • 2387
    Re: IR3220 Drum Info
    the chip will not improve your copy quality alone. You would have to install a new drum and charging roller with the chip to improve your image quality and that would only last for a little while till your starter in the drum unit wore out.
    yes you can move drums between machines.
    rebuilt drum units never last the way OEM drums do and usually end up causing a bigger headache in the end due to toner dumping and the issues that causes in the end.
    • Dalamar
      • Oct 2006
      • 117
      Agreed.
      Don't cut corners. Buy a new drum unit and be done with it.
      /thread
      Notatechie - "I am trying, but I don't know how to go into Service Mode. If I just go in and press *then 2, than 8, then * it does not do anything."
      SCREWTAPE - "Try harder.."
