Image pass B1 Problem
  • PrintCopyScanUK
    • Aug 2025
    [Misc] Image pass B1 Problem
    Hi Guys, i have a imagepass B1 currently down and i need to reload the software, easy enough if i could get the damn discs.
    I currently have some in the post somewhere that dont seem to want to find there way to me.
    Does any one know of a location i can download this from? i can do it with Konica Minolta fierys. or if the software is the same as a konica minotle one.
    thanks in advance.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: Image pass B1 Problem
    REad PDF................acc-996.pdf
    • PrintCopyScanUK
      HI and thanks for the info, however its the system software discs that i am waiting to be delievered, the custumer as lost the originals and the ones shipped out for me 2 weeks ago have not turned up, i have requested more but turnaround appears to be slow.
      Any ideas where i can download this from.
      thanks
      • zoraldinho
        • Mar 2008
        • 5018
        You can,t.
        • PrintCopyScanUK
          Thought that would be the case!!! gggggggggrrrrrrrrrrrrrrrr......
          • vigour
            • Aug 2010
            • 1038
            you can load it on to a 8 gig flash drive , if you expect to reload more in the future.
            • richardnarva
              • Mar 2011
              • 2
              buenas tienen el sistema de la b1 podemos intercambiar con otros modelos o marcas
