Canon CN3570 and Scangear
  • kuby
    • Oct 2007
    • 1410
    #16
    Re: Canon CN3570 and Scangear
    What program are you using to scan with? Scangear has to work with versions of MS Word or Acrobat Standard or Professional.
    • Omuser
      #17
      Omg! I never thought about it! thanks it is helped!
      And new problem.
      "The necessary file is corrupted, not found or the settings are incorrect"
      I hate it already.
      Win7x64 Acrobat Pro. ScanGear 2.3
      and there are no autrans.dll file anywhere
      • teckat
        • 16083
        #18
        And new problem.
        I hate it already.
        Version 2.3 of Network Scangear will install onto 64 bit operating systems but has to be used in 32 bit compatibility mode.
        Network ScanGear driver cannot be started at the same time as the ScanGear Tool. If the ScanGear Tool is running, close it.
        Network ScanGear is started by accessing it from a TWAIN compliant application as follows:
        1. On the imageRunner copier, press the Scan button. Press Online.
        2. On the PC, start the TWAIN-compliant application.
        3. In the application, select Network ScanGear as the scanner to be used. In the application, choose the command that selects a scanner, then select Network ScanGear in the dialog box that appears. After doing this operation once, there is no need to repeat it.
        4. In the application, choose the command that starts scanning operation (for example, "Scan New" or "Acquire"). The Network ScanGear Main Window appears. Individual items in this window are explained below. NOTE:
        See the documentation provided with your software application for commands and procedures used to select Network ScanGear and start scanning.
        The window that appears when Network ScanGear is opened in an application is called the Network ScanGear Main Window.
        The Network ScanGear Main Window includes the following items.
