V2 finisher upgrade using Downloader pcb
  • tonerlung
    • May 2008
    • 27
    Hi All,
    Does anyone know the correct settings for the dip switches on a V2 finisher when using the downloader pcb to upgrade the firmware.
    Thanks in advance
  • charm5496
    • 2387
    Re: V2 finisher upgrade using Downloader pcb
    you can upgrade the V2 using the SST and doing a single if I remember correctly.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      • tonerlung
        • May 2008
        • 27
        The firmware I am trying to install is supplied as seperate files from Canon Remedy and cannot be istalled using the single link in SST, it can only be done with the downloader pcb.
        • teckat
          • 16083
          what is Canon Remedy ??? where is this separate file stored ?
          u need SST & Downloader connected to acquirer the finisher firmware
