canon ir 105
  • tariq65
    • Jun 2010
    • 84
    canon ir 105
    canon ir 105 error E000014-0000 how to remove
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: canon ir 105
    Check fixing motor and motor connector.
    • jiongpao
      • May 2009
      • 413
      Re: canon ir 105
      Check all the bushings at upper roller make sure it turn not too tight. Also check the 24T gear and all the gears around fixing motor make sure it wont crack and thirst. Try to reset the error code.
      • tariq65
        • Jun 2010
        • 84
        Re: canon ir 105
        thank to all no is working
        • zoraldinho
          • Mar 2008
          • 5007
          Re: canon ir 105
          what did you do?
          • jiongpao
            • May 2009
            • 413
            Re: canon ir 105
            We need a feedback, tariq65
