canon IRADV 6055 lines/shadow
  • sevkln7of9
    • Mar 2009
    • 11
    We have a 6055 with 7k creating cross feed shadows intermittently on prints, I've included a picture, any thoughts? No errors or alarms. Thanksphoto.JPG
  • charm5496
    • 2387
    Re: canon IRADV 6055 lines/shadow
    have you checked the drum cleaner, carona assemblies? What work has been done?
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Try this:
      • charm5496
        • 2387
        Originally posted by zoraldinho
        Try this:
        [ATTACH=CONFIG]13472[/ATTACH]
        The lines are in the cross feed direction
        • sevkln7of9
          • Mar 2009
          • 11
          Adjusted DV contacts, reseat drum and coronas. Thanks for the replies.
          • copymech
            • Sep 2011
            • 196
            look closely at the fuser inlet guide and remove any toner build up. This may be causing a pause when entering the fuser. usually affects long paper sizes, ltrr ect. The paper hits the fuser and is still under drum when shadow appears.
            • ps/pcl
              TECH SPECIALIST
              • Jun 2008
              • 35
              I had similar problem in three machines,It was due to dev bias contacts.After adjusting It is working fine
