ir5870c display
  • Apach
    • 157
    ir5870c display
    Hello, again
    I have problem with display. When Im power device display working OK cca 2-3h then touch position is changed as about 30% to left side. Im thinking maybe problem in cable but Im not sure. Are there procedures for re-calibration touch screen? Tnx
    There is no stupid question, just stupid answer
  • teckat
    • 16083
    Re: ir5870c display
    Originally posted by Apach
    Hello, again
    go in service mode----------------
    COPIER>FUNCTION>PANEL
    LCD-CHK Check the LCD for missing dots.
    Method of Operation
    1) Select the item, and press the OK key to start the operation.
    In response, the front of the touch panel goes on as follows: white, black, red, green, blue.
    2) Press the Stop key to stop the operation. (If a printer model, press the Clear key.)
    TOUCHCHK -Use it to adjust the coordinates of the analog touch panel.
    Method of Operation
    - use it to match the points of press on the touch panel and the coordinates of the LCD.
    - perform this service mode if you have replaced the LCD.
    1) Select 'TOUCH CHK' to highlight, and press the OK key.
    2) Press the symbol '+' appearing on the touch panel in sequence (9 points) to end the adjustment.
    • Apach
      • 157
      Re: ir5870c display
      Tnx very much. I try to find touch adjust but I dont se TOUCH CHK on page 1072 in SM. Im to old
      • teckat
        • 16083
        Re: ir5870c display
        page 891 of 1100
        in service mode> select COPIER>FUNCTION>PANEL
        it's under function
        • Apach
          • 157
          Re: ir5870c display
          In my SM page 1072 of 1368
          Tnx
          P.S.
          What is the latest version of FW for ir5870c ?
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5007
            Re: ir5870c display
            last system software.pdf
            • teckat
              • 16083
              Re: ir5870c display
              [QUOTE=Apach;263996]In my SM page 1072 of 1368
              Tnx
              P.S.
              Firmware in USA is for 5870U -- v31.01
              • creppy
                • Nov 2009
                • 28
                Re: ir5870c display
                Hello, again
                check and clean touchscreen flexible cable or replace touchscreen
