Print option for canon gp405
  • danwatt
    • May 2025
    Hi
    please can some one assist me with how to configure the print option for canon gp405 that has printer serial port
  • vigour
    • Aug 2010
    • 1038
    Re: Print option for canon gp405
    the serial port in the front is for upgrading the ip board.
    you need an optional controller with parallel and ethernet ports
    • johnsonokram
      which tools to use to upgrade the firmware of gp 405 printer board..
        • 16083
        The machine may be upgraded in either of the following two ways:
        • By replacing the DIMM on the image processor PCB.
        • By updating the DIMM contents through downloading from a computer.
        The DIMM (flash ROM) used in the machine comes in two types; both types are mounted on the image processor PCB.
        • DIMM for the IP-CPU
        4 MB: bottom of 2-layer slot
        1 MB: top of 2-layer slot
        • DC-CPU DIMM (1 MB)
        Obtain the following:
        • PC to which the downloading tool (service tool) has been installed.
        • Bi-Centronics cable (with an IEEE 1284 Standard-compliant marking)
        Downloading/////////Connection
        • Check to make sure that the communication memory lamp is off.
        1) Turn off the machine's main power switch; then, disconnect the power plug, and disconnect the modular cable (telephone).
        2) Open the front door, and open the connector cover for downloading.
        3) Connect the machine to the PC with a bi-Centronics cable.
        • Make sure that the PC is off.
        • Connect the 25-pin connector of the cable to the PC, and 36-pin connector to the machine.
        4) Slide the switch to LOAD.
        Turn on the PC, and start the downloading tool.
        6) Connect the machine's power plug to the power outlet, and turn on the main power switch.
        Downloading
        1) Select 'To Main Menu' in response to the start-up message of the downloading tool.
        2) Select 'Next' under the Download/Upload.
        3) Click the model and PCB for downloading.
        IP: DIMM for the IP-CPU
        DC-CON: DIMM for the DC-CPU
        4) Start upgrading the flash ROM following the instructions on the PC screen.
        5) When downloading is done, operate as follows to turn off the PC:
        c. After Downloading
        1) Turn off the machine's main power switch, and disconnect the power plug.
        2) Disconnect the bi-Centronics cable from the PC and the machine.
        3) Slide the download switch to COPY.
        4) Close the connector cover, and close the front door.
        5) If the machine is equipped with fax functions, connect the modular cable.
        6) Turn on the main power switch.
        7) Start service mode, and check the ROM version. COPIER> DISPLAY>VERSION
        • Hasan abdelrazek
          • Sep 2017
          • 3
          Originally posted by teckat
          The machine may be upgraded in either of the following two ways:Obtain the following:Downloading/////////ConnectionDownloading1) Select 'To Main Menu' in response to the start-up message of the downloading tool.2) Select 'Next' under the Download/Upload.3) Click the model and PCB for downloading.IP: DIMM for the IP-CPUDC-CON: DIMM for the DC-CPU4) Start upgrading the flash ROM following the instructions on the PC screen.5) When downloading is done, operate as follows to turn off the PC:c. After Downloading1) Turn off the machine's main power switch, and disconnect the power plug.2) Disconnect the bi-Centronics cable from the PC and the machine.3) Slide the download switch to COPY.4) Close the connector cover, and close the front door.5) If the machine is equipped with fax functions, connect the modular cable.6) Turn on the main power switch.7) Start service mode, and check the ROM version. COPIER> DISPLAY>VERSION
          Thanks for this info but this method for reload systems machine not for printer firmware so how I can get the loader and printer firmware files to reload printer systemThanks alot
            • 16083
            Product Firmware is NA-----------
            Time to get into 21st Century---------get a good reliable newer refurb or newer model
