AnyOne Please Help me....
  • madhusel
    • Dec 2011
    • 12
    [Error Code] AnyOne Please Help me....
    i am facing error code e00064-0000 IN IR 3300 MACHINE, I HAVE REPLACED THE DRUM, AND ALSO CHECKED THE HVT PCB, STILL THE PROBLEM OCCUR, PLEASE ANY ONE GUIDE TO SOLVE THIS ISSUE THANKS IN ADVANCE....
    THANKS AND REGARDS
    MADHUSEL
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: AnyOne Please Help me....
    E064-0000
    The presence of a high-voltage error is communicated by the composite
    power supply PCB. (The output for primary charging, developing, or transfer
    has deviated from a specific level of voltage.)
    Main cause The contact has poor connection. The wiring is faulty. The composite power
    supply PCB is faulty. The DC controller PCB is faulty.
    Action
    1. Contact
    Is any of the contacts of the primary charging roller, developing assembly,
    or transfer charging roller soiled? Or, is there poor contact?
    YES: Clean the contact, and set it once again.
    2. Wiring
    Is the wiring between the contacts for the following normal: DC controller
    PCB (J301), composite power supply PCB (J136), primary charging roller,
    developing assembly, transfer charging roller?
    a. DC controller PCB (J301) <-> composite power supply PCB (J136)
    b. composite power supply PCB (J130-7) <-> primary charging roller contact
    c. composite power supply PCB (J130-1) <-> developing assembly contact
    d. composite power supply PCB (FT133) <-> transfer roller contact
    NO: Correct the connection.
    3. Composite power supply PCB, DC controller PCB
    Try replacing the composite power supply PCB. Is the problem corrected?
    YES: Yes.
    NO: Replace the DC controller PCB.
    • dhanesh
      • Jun 2010
      • 63
      did u reset error and ram clear?
      DHANESH
      • mramlawi
        • Jul 2011
        • 838
        once Happen with me at the same machine and it was weakens on Electricity so check the power of the Socket try to plug it directly without any extanstions.
        regards
        Distinguished road makes you jewel in rough
