ir7095 print blur
Re: ir7095 print blur
The measured and target values (VL1M and VL1T) (VDM and VDT) in DPOT, SERVICE MODE>COPIER>DPOT, should be relatively close in value. When the measured value of VDM (VOLTAGE DRUM/DARK) is close to the value of VL1M (VOLTAGE LIGHT)\
SCANNER LASER AND BLANK LAMPS should be investigated because the primary voltage is not being dissipated by light.
Check visually to make sure that blanking lamps are coming on. Replace LED ARRAY Unit if needed. = FH7-3395-020
Check the the laser shutter. When the shutter is not open fully, the VL1 value will rise. Bent actuator may be the cause.
Replace the Laser Unit. The part number for the Laser Scanner Assembly is FM2-5449-010.
CHECK DEVELOPER
If copies and prints are light, check the coating of Toner on the Developer.
Set a copy run of 25~50 copies. Once started, go into service mode Copier>Display>DPOT and see what VLT is reading (normally around 65~70 volts). Next check VLM and what that reading is (this should be close to VLT). In cases where VLM is much higher than VLT ( such as VLM= 200) the Laser Scanner power is to weak, and could not bring the voltage down to correct target. If Adjusting Laser Power in Service Mode does not correct problem -replace the Laser Scanner Assembly (FM2-5449-010) -
also check
DC controller.
HVT, Primary Corona ????**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Do you get an E110 in addition sometimes?
if so, replace the laser Diode assy, not the whole Laser Unit.
Part Number: FM2-8146-000
Btw.: if you perform a panic stop, how does the toner image at the drum surface looks like? is it palish too? if so, go the laser way, if not, go for transfer related things. Try to raise the transfer corona wire 1mm and lower the sep corona wires 1mm, does the quality become better?If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!Comment
take a look at this picture to see what FUNCTIONS are attached to DCPCB-
this is a wiring diagram <_-_>-& not the direction of signals.
DC.JPG**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
thank'sComment
First you must have a shematic diagram of the DC Con ,locate which IC is driving the HVT unit.
Then you must have equipment for handling SMD's because all IC's on the DC Con are SMD's.
You must have the replacement IC, it's not easy to get.
Replace the IC's one by one until the DC Con is OKComment
There are some soldered fuses (2Amp/125V, if i remember correctly), maybe it is a good idea to check them first. Had this several times, they are easy to replace, just cut them out and solder new fuse to the remaining wires.If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!Comment
