how to check sending board errors
Sending board
Tags: None
Re: Sending board
if you use the search box that is located in the light blue banner at the top the codes are posted in here already. What problem are you having with yours?Accidents don't just happen. They must be carelessly planned. -
Re: Sending board
sounds like the customer might have changed something on their network configuration or server possibly. If you go into the status monitor it will give you an error code. what is that number?Accidents don't just happen. They must be carelessly planned.Comment
Re: Sending board
ir 3320i cant scant to ftp server but i was scaning beforeIf sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!Comment
Re: Sending board
nothing changed. machine works fine for some time . after that i doesnt scan. ater restarting it works fine againComment
