For fear of getting my ass chewed off, looking for IR2270 Firmware
Re: For fear of getting my ass chewed off, looking for IR2270 Firmware
I need the firmware because I had to replace the ADF DC Controller PCB. For reasons unknown it can read paper sizes when copying but when we go to fax, no matter how I change the setting in the service mode, it thinks all the paper is 11" x 17"
Enter Service Mode > FEEDER > FUNCTION > TRY-LTR, move tray side guides to the LTR / 11x17 position and press [OK].
Press TRY-LTRR, move tray side guides to the STMT/LTRR/LGL position and press [OK].
Press Reset key twice to end Service Mode. Hold the power switch on the control panel until the shutdown screen displays and then press [start]. Wait for the message that indicates the main power switch can be shut off and then shut the main power switch off. Turn the main power switch on.
Note:The result of the Tray Width adjustment is stored on the reader controller pcb.
As such, unlike previous ADF's, you will need to make this adjustment at the time of installation or after RCON CLEAR, so that the result is stored in the reader controller pcb.
do the same for AB-Configuration
FEEDER>FUNCTION>TRY-A4
adjust tray>to A4/A3
TOUCH OK TO REGISTER A4 WIDTH
TOUCH>A5R
adjust tray>to A5R
TOUCH >TRY-A5R TO REGISTER WIDTH
firmware would not have solved this issue.
I really wish the untrained would post the problem they are having first so those of us who are trained could help with a solution.
Not to be offensive, but this is the same kind of technician who would go to the auto parts store and buy an alternator because his car's battery wasn't charging, just to find out that the ground cable was loose. Then he would try to return the alternator for a refund...
As I said, I am looking for the firmware for an IR2270. Will purchase or trade for material I already have.
Assistance is appreciated, thanks in advance.
At least you offered something in return, and for that I thank you.
