I have issue in print in driver for IR5570 i get margin more then 5 mm but if I use driver for IR5000 is lover then 5 is there any solution to use original driver with margin lover then 5 (4.9 would be ok)
IR5570 Print driver margin
Re: IR5570 Print driver margin
Have you checked your margins from your PG-type 5 to see that it is within normal specs?
something else to keep in mind is that some programs also change the margins as well depending on the OS and version of the program.Accidents don't just happen. They must be carelessly planned. -
Typically, most Canon drivers have about the same void area, about .17", or about 5mm (at least in theory, anyway).
If you don't need any special features, you may be able to get away with an HP driver, like a LaserJet 5.
I had a customer about 9 or 10 years ago who had 2 iR330s which had fairly large areas (much more than 5 mm), and their application required a printer that would just about go to the edge, as it was designed by short-sighted engineers who thought that everybody has an HP.
The LJ5 drivers worked perfectly. Fortunately, the customer didn't need any special finishing.
At one time I tried hacking a few of PostScript drivers to minimize the voids, but only had very limited success.“I think you should treat good friends like a fine wine. That’s why I keep mine locked up in the basement.” - Tim HawkinsComment
do you have the latest print drivers installed? which printer language are you using UFR/PCL or PS?
something else to keep in mind is that some programs also change the margins as well depending on the OS and version of the program.Comment
Hi, jemsovic
Have you try from the printer driver properties "Finishing" tab -> "Advanced Settings" button, which offer a few tweaks?
Expand Print Region.jpgComment
Accidents don't just happen. They must be carelessly planned.Comment
