ir adv 8105 display blank.
  • eurokris
    • 120
    [Misc] ir adv 8105 display blank.
    hi good day to all.
    irc adv 8105 when on machice display blank.if dismental hdd cable showing E602.
    pls anyone advice me.
    thanks
  • teckat
    • 16083
    Re: ir adv 8105 display blank.
    Originally posted by eurokris
    hi good day to all.
    thanks
    why would take the cable off the HDD ?
    CHECK if the control panel cable is locked into place.
    Try properly re-seating it and making sure it locked into place--
    Be sure to check the cable at both ends. One end is on the control panel and the other on the side of Main Controller PCB 1. Check the images below in reference to the connections of this cable. If the cable does not lock into place, replace the cable. The part number for the cable is,
    FK2-8330-000, CABLE, USER INTERFACE.
    Control Panel location
    Main Controller PCB1 Location
    Also check your 12V Power Supply Assembly (FM4-5131-000)
    • eurokris
      • 120
      panel light got.but display blank.cant reboot.
