Canon IR 5000 & Network Scangear
  • Philh
    • Dec 2011
    • 27
    I have desktops and also a laptop successfully connecting to a Canon IR5000 copier and also scanning through the wireless network using network scangear 2.1.
    I recently setup a new laptop with both the Canon driver and scangear software but while I can get it to go through the copy process it will not scan through Adobe Acrobat 8 Pro - when I
    set up the scanner through the scangear tool it correctly identifies the scanner in "discover" and passes the scan test. However in Acrobat I get a message to the effect that Scangear is corrupt and that it is Acrobat will not recognize this.
    I have tried both uninstalling Acrobat and NSG but with no difference. The other computers are running the same versions of Windows, Acrobat and NSG. I do not think it is a netork problem as if I take the other laptop home (i.e., outside the office network AND the Canon copier I will just get a message scanner not found, but on the new laptop I get the same file corrupted etc message.
    Sorry if I have posted this to the wrong forum and if so please advise as to the most appropriate forum.
  • teckat
    • 16083
    Re: Canon IR 5000 & Network Scangear
    SEARCH for files that are named autrans.dll
    NetworkScanGear uses it>
    it will cause a conflict if another program also uses this .dll file
    similar files are actually different files but in different locations.
    if u remove/
    rename the conflict>that program may not function /
    Possible Workaround if other program is needed-----
    By changing the path statement and putting the path for ScanGrear first both programs should work.
    • bnmand
      • Sep 2008
      • 383
      What version of Windows is it?
      Though it may not be necessary for the version of Windows you are using I would recommend you use Network ScanGear v2.30. This new version is compatible with Windows 7 64-bit.
      This version works fine for me on both Win XP 32-bit and Win 7 64-bit (I haven't tried other Windows OSes).
      • teckat
        • 16083
        WinDriverMatrix Windows Drivers - Supported Device List read---------------WinDriverMatrix.pdf
        Utility - Supported Device List
        Network ScanGear
        Color Network ScanGear
        WIA Network ScanGear
        read-------------UtilityMatrix_10112011.pdf
        • charm5496
          • 2387
          if u remove/
          nice information teckat!!!
          • mramlawi
            • Jul 2011
            • 838
            Thanks Teckat
            Distinguished road makes you jewel in rough
