Canon iR 3300 Drum
  • iscott
    • Mar 2010
    • 344
    Canon iR 3300 Drum
    How hard is it to change the Drum and Blade on an iR 3300? or is it better to just replace the whole Drum Unit?
  • charm5496
    • 2387
    Re: Canon iR 3300 Drum
    its not worth the time to replace the individual parts, just get a unit and install that way.
    • bojans
      • 1313
      It's easier to install new drum unit, but changing OPC and blade isn't so hard. Used to change these OPC kits from katun. They lasted for 100K, but after 300-400k you have to change whole unit, cause there were problems with charge roller.
      • kuby
        • Oct 2007
        • 1409
        Yes it is not hard, I have been doing them for about 5 years and never had a problem. Drum and blade kit cost about $16.25 and takes about 30 minutes to do. We rebuild them about 4 to 5 times and then the PCR starting going bad so we buy another one and start the process over.
