Canon IR3035 Blank Prints and Copies
  • Onetouch
    • May 2008
    • 62
    I have Canon IR3035 and I'm getting blank print and copies. When I change the drum it prints for a day or so and then it starts to give me blank paper again. Has anyone ever had such as problem?
  • westsoo
    Re: Canon IR3035 Blank Prints and Copies
    maybe the toner problem
    • Onetouch
      • May 2008
      • 62
      Toners problem doesn't give a blank copy. It must be charging or something else because I already have replaced the drum Assambly and it happened again.
      • westsoo
        Sorry I forget ask u ,what toner u use is that compact toner
        • Onetouch
          • May 2008
          • 62
          I use compatible toner but as I said it has nothing to do with the toner.
          I use this toner in so many machine and I have never had a problem
          • blazebusiness
            SanDiegoCopierRepair.com
            • 1257
            I would start by making sure drum & developer cylinder are turning. If not you've got a problem with the dev clutch or main motor slipping . Laser issue is also a remote possibility.
            • charm5496
              • 2387
              dont assume its not the toner. If it is "compatible" and not OEM it can cause all kinds of issues especially if leaks down the back of the machine into the HVT's and power supplies.
              Off brand toner will wear out odd components faster than the OEM because it is manufactured at a lower quality which over time can cause all sorts of image quality issues.
              Like others have stated make sure your developer unit will turn by hand.
              See if it is driving during copying sequence.
              check your your laser shutter. This one has got me before
              also make sure that your laser is seated correctly. Had another tech cause this issue on me as well
              • Onetouch
                • May 2008
                • 62
                Problem was the belt for the drum unit worn out.
                I replaced the belt and is fine now.
                Thanks for your help.
