canon-5800-E00013-002
  • SAMER
    • Jul 2025
    [Error Code] canon-5800-E00013-002
    hi
    I have a Canon printer 5800ir
    and i have Problem with my printer
    problem
    ERROR Code
    00013-002 AND
    00075
    HELP ME Please
    ERROR Code
  • charm5496
    • 2387
    Re: canon-5800-E00013-002
    E013 is a waste toner error. Your tube is probably packed up and the toner cannot empty into the waste box.
    E075 deals with your ITB and timing. A subcode would be needed to narrow down what the problem is.
    • teckat
      • 16083
      U need to pay attention to control panel messages on waste bottle
      E013-0002 (waste toner feed-screw error) indicates that the output of the waste toner lock detecting switch (SW1) is "1" for 1 sec or more. (If the waste toner feed-screw fails to rotate when the developing motor (M3) is driven, the waste toner feed-screw is pressed in the direction of the arrow, thus turning on SW1.)
      Waste Toner Bottle has to be emptied and SW1 checked/
      u also need to check/unclog the tube/slight bang on tube should release clog and SW1
      after all that>>>>>>>>>>
      The counter for the Waste Toner Bottle needs to be reset back to zero in Service Mode.
      Enter Service Mode level 1 by pressing * 2 8 *, select Copier > Counters > MISC, then highlight WST-TNR, press Clear - the counter will zero out.
      Power off the copier, turn the copier back on--
      • SAMER
        [ATTACH=CONFIG]13702[/ATTACH]
        Thanks to all of you have helped me already ~ Thank you again
        • SAMER
          Thanks FOR Help
