Error code E246 on IR2018
  • Rachid.Akli
    • Oct 2011
    • 595
    [Error Code] Error code E246 on IR2018
    I replaced the counter PCB with a new one and i have the same code in intermitance with normal display. Is there any proceddure for this model after replacing the counter pcb?
    Thanks in advance.
    Rachid.
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Re: Error code E246 on IR2018
    Thanks in advance.
    Rachid.
    Why did you replace the counter pcb? Put the old one back in to fix the problem.This error code occurs when the counter board malfunctions or if a counter board from a different machine is installed in the one experiencing the error code. The counter board must stay with the original copier. If you search this forum there are tons of posts on this code.
    • teckat
      • 16083
      Thanks in advance.
      Rachid.
      E246 Error in writing operations (to the counter memory)
      READ PDF>>>>>>>>
      iR B&W Counters_TP05 108d.pdf
