irc 3220 error
  • pontiac
    • 420
    irc 3220 error
    E000677-0010 keeps poping up during warmup do i have a fiery issue . I looked for code in service manual and could not find it. Thanks for replys.
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1254
    Re: irc 3220 error
    Found The following info:
    1)Error E677 occurs when sending print jobs to any printer on the network that has an imagePASS C1 or C2 Fiery controller attached to it.
    Workaround :
    1. Verify the copier and the imagePASS C1/C2 have the latest system software installed.
    2. Verify that all posted patches for the RIP (either the imagePASS C1 or C2) have been installed.
    3. Try reseating the Open Interface Board in the copier.
    4. Try reseating the interface cable.
    5. Try change from the PCL print driver to the PS print driver.
    2)E677 code
    Workaround :
    E677 refers to an error detected by the print board (PDL) or an error detected in the hard drive.
    Replace as necessary
    3)Problem :
    E677 error code
    Solution :
    In some cases it has been found that replacing the cable between the ImagePass C1 and the copier resolve this problem.
    Additionaly, make sure that the copier is at a minimum of ver. 55 system software.
    • teckat
      • 16083
      Re: irc 3220 error
      1-when did u install this printer ?
      2-where did the fiery come from ?
      3-what is printer firmware ver.?
      4-what is fiery firmware ver. ?
      5-have u checked the interface cable>from fiery to printer ?
      **Before connecting the cabling to the imagePASS make sure you first go into Service Mode and set the IMG/Cont to "3" and then hook up the cabling to the engine and restart the engine.
      • pontiac
        • 420
        Re: irc 3220 error
        Thanks guys for the help. I went thru 2 cables before i realized they were not clipping on properly. Thanks again
        • teckat
          • 16083
          Re: irc 3220 error
