Our old workhorse has started showing signs of the toner "chalking" from the front of one sheet onto the back of the sheet on top of it. It happens on all weights of stock (Texts to cover). You do have to rub the sheets together to get it to show, it doesn't happen if the sheets are just sitting on each other.
Now for the odd part. Yes the fuser is showing the right temp, and the actual image doesn't look like it is missing any areas after you rub the sheets together to get the transfer. Canon/Kodak support after troubleshooting has told us that this is normal for the machine. Does this sound right? Also for double sided stuff, the second side (the side that has run through the machine twice) doesn't seem to have this issue. Any ideas?
Attached is a digital photo from my iPhone, hopefully it is clear enough to make out what I am referring to. I did circle the areas in question.sample.jpg
