Canon fax l280
  • technician
    • Aug 2010
    • 25
    [Jamming] Canon fax l280
    Hello Every Body.
    I have a fax machine canon l280.
    I error message show "check paper size" while machine print multi copies.
    I changed the feedroller and checked sensor but problem remain same.
    Have any idea about this problem please share me your comments.
    I am waiting for your reply.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5000
    Re: Canon fax l280
    1) Check if more than the regulation amount of paper is loaded in the
    sheet feeder.
    (2) Clean the paper pickup roller.
    (3) Replace the paper pickup roller.
    (4) Check whether the paper edge sensor actuator is damaged or
    deformed.
    (5) Replace the pickup solenoid.
    (6) Replace the paper edge sensor.
    (7) Replace the SCNT board.
    Usually is LEVER, REGISTRATION SENSOR worn out.
