CANON IR5000 E00061-0001 !
  • gensys
    replied
    Re: CANON IR5000 E00061-0001 !
    E061-0001 is generated when potential control is being performed
    After the power is turned OFF/ ON, a jam (0A07) is displayed
    In this machine, potential control (default) is performed when the fixing unit temperature is 150 C. or lower when the main power is switched ON.
    Potential control can be toggled ON/ OFF in service mode COPIER> OPTION BODY> PO-CNT.
    E601-0001 detection :
    When the result of potential control is that the white drum surface potential (VL2) is around 200V (the potential for a solid black image).
    To Check
    When E061-0001 is displayed when electropotential control is ON, check the following under service mode COPIER> DISPLAY> DPOT>
    For each item, the normal values and error values are given below.
    'VDT' copy bright area electropotential target value (Normal 390V Error 390V)
    'VDM' copy bright area electropotential measurement value (Normal 390V Error 0V)
    'PLMT' copy primary charging current control (Normal 0 Error 1)
    When there is no primary charging on the drum surface during electropotential control, VDM (copy bright area electropotential measurement value) becomes 0 and PLMT tries to raise the primary output during electropotential, so 1 is displayed.
    Also, as primary charging bracketing, the normal values and primary output error values are given below. When the laser output is normal, LLMT is 0.
    Check the following items under COPIER> DISPLAY> DPOT>.
    'VL1T' copy bright area electropotential target value (Normal 115V Error 115V)
    'VL1M' copy bright area electropotential measurement value (Normal 110V Error 0V)
    'LLMT' copy laser power voltage control (Normal 0 Error 0)
    Check for any broken primary charging wires or leak from the primary charger.
    in iR 5000 series mashins>>> error 061-0001 may be also...................
    When copy power is switched ON, caused by malfunction of the manual-feed door open detection sensor (MSW2).
    Open and closed status of the manual feed tray assembly is detected by the manual feed tray open/ close sensor (PS33) and the manual feed door open/ close detection sensor.
    The manual feed tray open/ close sensor (PS33) detects that the manual feed tray is closed and, due to a malfunction of the manual feed door open/ close detection switch (MSW2), or a broken wire, there is no 24V output from the inrush current protection PCB to the HVT PCB, so there is no primary charging voltage output and if a malfunction occurs in the manual feed door open/ close detection switch (MSW2), error E061-0001 is generated.
    Field Remedy
    Check the manual feed door open/ close detection switch (MSW2) and the mounts and cables around the switch. If the switch is malfunctioning, replace it.
    FG2-6932 High voltage switch unit
    Anyone help You
    Good Luck
  • alaa1005
    replied
    That is mean the problem in potential control so turn it off from option in service mode and check if the error appear again.
  • sweet.persona
    started a topic CANON IR5000 E00061-0001 !
    Hello friends
    i have ir5000 copier , Appear an err E000061-0001 , i have reset the machine but the err was still consistent !I have checked The laser shutter / laser unit is not faulty DC controller too is not faulty but In vain ,LCD still displays this damn err ^^.
    can anyone help me . Lot of thankx
