The error code E602-0001 appeared when I turned on the Canon IR3080i. What does this error code mean? Can I reset this error? How do I make the reset? Please help what to do...??
Canon IR3080i E602-0001 error code
Re: Canon IR3080i E602-0001 error code
You need to load again the firmware from computer to the machine using the SST software. Make sure you got the firmware of that machine and the software of SST (Service Support Tools). If you got these those things then you can search on this forum about how the procedure for e602. I believe theres a several cases and way solutions once you search. -
You need to load again the firmware from computer to the machine using the SST software. Make sure you got the firmware of that machine and the software of SST (Service Support Tools). If you got these those things then you can search on this forum about how the procedure for e602. I believe theres a several cases and way solutions once you search.COBRAComment
