No Scan Button on the touch panel
  • nochick
    • Jan 2012
    • 80
    [Misc] No Scan Button on the touch panel
    I used to use Canon iR 3300 / 4570 / 6570 every machine have Scan button
    But i just buy 2nd hand iRC3220 From Friend and there's no Scan Button on the touch panel / there're have Copy-send-Mailbox
    Do i have to use MEAP ??
    Or what can i do?
    Thank you
  • DANIELCANON
    • Jun 2011
    • 187
    Re: No Scan Button on the touch panel
    *28*
    *2 (LEVEL 2)
    COPIER
    BODY
    UI-RSCAN:1 esta opcion debe estar con valor 1.
    • nochick
      • Jan 2012
      • 80
      gracias
      Voy a tratar de
        • 16083
        Or what can i do?
        Thank you
        ALSO CHECK>>>
        A simple way to verify that a Resolution Switching Board (Send Board) is installed in the imageRunner is to check in Service Mode.
        *28* > Copier > Display > ACC-STS > SEND
        SEND will indicate "0" if NO Resolution Switching Board in installed
        SEND will indicate "1" if the Resolution Switching Board is installed
        If the imagePass C-1 or the Multi-PDL printer board A1 is installed you must also have the Resolution Switching Board installed.
        If the Resolution Switching Board is not installed, the scan button will not be enabled on the control panel.
        To identify if the Resolution Switching Board is installed, and installed correctly, first look at the board slot covers on the cage unit at the back of the imagerunner.
        The Resolution Switching Board is NOT installed if the second cover from the bottom has two bumps (nipples) diagonally across from each other. If the plate surface is flat, the board is installed.
        Next, check that the board is installed correctly. Remove the back cover of the Color imageRUNNER copier.
        Once the back cover is removed, the metal plate has to be unscrewed.
        Note: When removing the metal plate, be careful not to break the fan wire and not to damage the power supply.
        The Resolution Switching Board is pictured Below. It is installed in the second PCI slot from the bottom. Re-seat the board to refresh the connections.
        WARNING:
        Power off the imageRUNNER before disconnecting any electrical components.
