ir7095 Unable to print
  • jiongpao
    • May 2009
    • 414
    Hi, I been setting up the network and configuring everything to connect the ir7095 to computer through RJ45 to router and computer just like what i did normally to other machines. But after i set the IP address theres no respond when i print. I did installed the ir7095 driver. I just remember that does this machine bootrom come with optional C version and N version? Theres a network port and USB port at the side of the machines. I even restore back the setting to factory default inside additional function but still cant print after setting back the ip. From computer i can ping the machine IP and router IP just it cant print nothing message coming out and no respond at all from machine. Others IR7095 working find with same method
