CLC3200 Dead Hard drive
  • seanmcinnes
    • Jul 2025
    I have a CLC3200 with a dead hard drive, is there anyone who could offer advice on how to get it going again? I have another CLC3220 but reading another post it seems that it is not possible to clone that drive and insert, thought I would ask before starting! I obviously have a new IDE drive ready to install but wondered if there is somewhere you can pickup an iso image for what should be on the disk by default? Thanks in advance.
  • gensys
    • Jan 2011
    • 323
    Re: CLC3200 Dead Hard drive
    Read this >>>http://www.copytechnet.com/forums/ca...-required.html
    See this >>>
    SST >>> IS THE WAY TO GO
    For best result. Call Canon Regional Service
    The Road will be Mastered by >>> the Going...
    • seanmcinnes
      Thanks for the input. I have read this thread - http://www.copytechnet.com/forums/ca...02-0602-a.html which suggests that swapping a drive from a similar machine is a bad idea, so I am really after the Service Support Tool relevant to the CLC3200 so I can hopefully start from a fresh hard drive. Otherwise I am quite familiar with cloning disks so would be happy to do that but am I risking messing something else up? The other machine I have is a CLC3220 which is also slightly different so I am not sure cloning the disk is the best idea? We do not have canon support and the engineer that normally helps me is more of a technical fix it rather than a software fix it!
      • teckat
        • 16083
        iR3220 SUPPORTED HDD's
        The Canon OEM # is WM2-5248-000 HDD, WD800BB-22JHC0.
        HDWN 'IC35L040AVER07-0
        HDWN 'IC35L040AVVA07-0
        HDWN 'IC35L060AVER07-0
        HDWN 'IC35L080AVVA07-0
        HDWN 'QUANTUM FIREBALLP AS40.0
        HDWN 'QUANTUM FIREBALLP AS60.0
        HDWN 'FUJITSU MPG3409AH E
        HDWN 'Maxtor 4D040H2
        HDWN 'SAMSUNG SP4002H
        HDWN 'MAXTOR 6L040J2
        HDWN 'MAXTOR 6L060J3
        HDWN 'IC35L060AVV207-0
        HDWN 'SAMSUNG SP0411N
        HDWN 'HDS722540VLAT20
        HDWN 'ST340014A
        HDWN 'HDS728040PLAT20
        HDWN 'Hitachi HDS721680PLAT80
        HDWN 'WDC WD800BB-22JHC0
