E000004-0202 in CLC4040
  • richard_hosea25
    • Aug 2011
    • 48
    [Error Code] E000004-0202 in CLC4040
    Can somebody help me what is this error E000004-0202 in my CLC4040 canon machine...Thanks..
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Re: E000004-0202 in CLC4040
    I believe your machine is equivalent to the IR C4080
    E004 Fixing unit protection circuit trouble.
    0202 When the difference in temperature between the center and front of the
    fixing belt is higher than the rating
    You could try to reset the code by clearing the error in service mode. If the code cannot be reset you'll need to replace the fuser. Hope this helps.
    • ikon01
      • Apr 2011
      • 53
      E000004-0202
      fixing belt is higher than the rating.
      Remedy
      Replace the fixing belt unit. Replace the DC controller PCB 2 (MAISY)
      Your going to need a new fuser unit i'm afraid!!
      • teckat
        • 16083
        CLC5151/CLC4040
        iR C4580i/iR C4080i
        same fix unit i believe
        i would inspect before i did a clear in service mode
        [Service mode > COPIER > Function > CLEAR > ERR].
        E004=Fixing unit protection circuit trouble
        0202 =When the difference in temperature between the center and front of the
        could be damaged belt or connector issue
        u may get lucky>
        Connectors of Fixing Feeder Unit Open/Closed Sensors may have poor contact.
        try this first---------
        1. Re-fit the connectors of the fixing feeder unit open/closed sensors in the main body side. If pins of the connectors are deformed, modify it.
        2. Check to see if the sensor lever is damaged.
        3. If the symptom still occurs, replace the sensors with new ones.
        next choice/ pull out the fix unit to inspect it
        • richard_hosea25
          • Aug 2011
          • 48
          Originally posted by ikon01
          E000004-0202
          Remedy
