Ir c2058 toner cartridge problem
  • Freckled Legs
    • Jan 2012
    • 8
    [Misc] Ir c2058 toner cartridge problem
    Trying to install new toner cartridges and cannot install tubes all the way back in machine. Is there a special installation procedure?
  • charm5496
    • 2387
    Re: Ir c2058 toner cartridge problem
    no there is not a special procedure. Shine a flash light up there and make sure nothing is blocking the tube from going in all the way.
    You also need to look at the sliding shutter which is item 7, figure 620, p/n FB5-1005-000. This can cause problems as well.
