Canon IRC 4580 error code 194 not in manual or in our Knowlegebase
  • racer42
    • 18
    [Error Code] Canon IRC 4580 error code 194 not in manual or in our Knowlegebase
    IRC 4580 with 194-999a error code. Replaced DCON2 Maisey per Navi suggestions. Colors are off in PF direction. Any Help would be appreciated.
    There I was, 20.000ft. surrounded by commies, no fuel, shot to hell, cockpit panel fire, in an inverted tailspin, and I had to pee...
  • charm5496
    • 2387
    Re: Canon IRC 4580 error code 194 not in manual or in our Knowlegebase
    Problem :
    E194-999A codes.
    Solution :
    E194-999A code is an image correction error. This can be caused by the DC controller (IMG) and/or the ITB assembly.
    Start by making sure the machine has the latest software on it. Next check the ITB assembly for worn parts and replace as needed. In this case replacing both the ITB assembly (FM2-5365-000) and the DC controller 1 (IMG) resolved the 194-999A code.
    • teckat
      • 16092
      to add on--
      another tech posted this pdf in the forum last year > credit to them
      Color Shift Prevention / Correction
      iRC4080i
      iRC4580i
      iRC5185i
      CLC4040
      CLC5151--------------see pdf--iRC5180_Color_Shift_Prevention _&_Correction.pdf
