canon ir 5055 wrinkled paper.
  • ernesto
    • Oct 2011
    • 430
    Hi everybody, I have a problem with a canon ir5055 sometimes it wrinkled paper, it always happens when there are more toner density, do you Know what the problem is ?. I look forward to answering from you.
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Re: canon ir 5055 wrinkled paper.
    How do the fuser rollers look. Is the lower roller coating compromized or wrinkled? Does it have flat spots?
    • charm5496
      • 2387
      lower roller shaft might be eaten up or the bearings are shot.
      • ernesto
        • Oct 2011
        • 430
        Thank You for the response . I am going to replace the roller pressure and the ball bearing.
        • ernesto
          • Oct 2011
          • 430
          Absolutly, the roller pressure and ball bearingroller pressure.jpg were replaced and the canon ir 5055 is working right again
          thank you very much
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5013
