Bad quality of print on Canon iR-ADV 6065
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    Hello! I have another particular problem to illustrate !
    I have a Canon iR-6065 ADV with the problem by dark background ...
    I replaced the primary unit charge, Developing Unit, Potential PCB, transfer belt ...
    I clean the drum with Cerium oxide ....
    Nothing, the fault persists!
    Only if I hold off control of the potential, the problem does not occur, but the copy or print quality is very bad!
    Tips?
    Thank you!
  • charm5496
    • 2387
    Re: Bad quality of print on Canon iR-ADV 6065
    check your contacts for the HVT on your developer assembly. They get pushed down and make a poor connection.
    • Ingranaggio_rotto
      • Oct 2010
      • 275
      Ok ... Controller and I'll let you know!
      • Ingranaggio_rotto
        • Oct 2010
        • 275
        Hi! I checked the contacts, cleaned with isopropyl alcohol ....
        But nothing has changed!
          • 16083
          internal HVT bias contact plate
          background is usually / BIAS or TONER issue / or Drum surface
          there is a 'Remove Background Density' button on the machine under the density button. The Density button is on the Copy home screen The background can be removed with two settings of Auto or Manual.
