iR2018 scan issue
+ More Options
Posts
  • Blues Guy
    • Aug 2009
    • 216
    iR2018 scan issue
    Good day to all of you,
    Had this canon ir2018 with the scanning issue. Using canon color scangear driver install it in the computer.
    When you scan 1 page on the document feeder wheather a text or jpeg image the machine no problem where the computer will receive it. But when scan multiple copy more than 2 page after the 1st page the machine will hang the panel red light will start blinking. At the computer will shown you a message "network is time out"
    Any one have come across these problem ? Thank you......
  • charm5496
    • 2387
    Re: iR2018 scan issue
    what do you have the resolution set at?
    this device only supports 300x300 dpi
    also what version of CNWSG are you running?
    • Blues Guy
      • Aug 2009
      • 216
      Where do set the dpi ? Do you required go to service mode or in the additional function ?
      Not check the version of the network scan gear driver which installed by the technician. If not mistaken current latest version is 2.7 . I 'm suspecting is the driver version to low on these problem.
