Show iR5075 e423.
  • Joesaima7749
    • 27
    [Error Code] Show iR5075 e423.
    Helpwith theiR5075showcodeE423.
    I thank you in advance.
  • charm5496
    • 2387
    Re: Show iR5075 e423.
    E423 may occur at power-on or during scanning.
    When the symptom occurs, perform the following remedy.
    - E423-0001 can be displayed when an SDRAM access error occurs.
    - E423-0002 can be displayed when an SDRAM verification error occurs.
    - E423-0003 can be displayed when an SDRAM unit number error occurs.
    Workaround :
    1. When a faulty image ascribed to CIS scanning side occurs at two-sided simultaneous scanning, re-fit J308 connector on the interface PCB, and then make copies.
    2. Suspect poor connection of the DIMM mounted on the backside of the memory PCB (FM3-4436-000) found in the reader unit. Remove the DIMM, clean its terminal with lint-free paper moistened with alcohol, re-fit the DIMM, and then make copies again.
    • Joesaima7749
      • 27
      Workaround :
      [ATTACH=CONFIG]13863[/ATTACH]
      Thank you very muchfor yourgreat help.
      • vandy
        Thank you so much for your help
