CANON GP160
  • COPIERTEC ASSOCIATES
    • Aug 2011
    • 279
    CANON GP160
    Hi guys, am working on a gp 160 having scanning problem.The machine warms and gets ready to copy.When you command to print,the scanner remains still at the same position and goes a head to pull paper out and eventually indicates paper jam.When you manually pull the scanner unit mid way and switch on the machine it goes back to home position and machine gets ready to copy,no error code shown. I have swapped the dc board,power supply,home position sensor,with no success. Assistance requested,thanks.
  • teckat
    • 16083
    Re: CANON GP160
    Scanner Motor / clock pulse in motor is probably toast
      • Aug 2011
      • 279
      Re: CANON GP160
      When printing check printer message does not appear. I also tried to swap scanner motor and main motor with no success.What is funny is that when machine is warming up,the error icon blinks for a while and the machine gets ready to copy.
      • teckat
        • 16083
        Re: CANON GP160
        check connections & voltage supply to the motor & scanner
