error code E000602 - 301
  • bigjoe
    [Misc] error code E000602 - 301
    Hi All. Can anyone help me please. my clc3200 is showing the error E000602-301. Anyone know what this is or how to fix it.
    Re: error code E000602 - 301
    Turn the machine off.
    Hold down 1 + 9 as you turn the power on and wait............
    If this doesn't work
    Call a tech.
      • 16083
      E602 The hard disk is faulty.
      03xx=The partition DOSDEV2 is faulty.
      01 =Device error: sector, write/abort, other HDD access (driver) error
      Storage of thumbnail display data of image data
      FSTDEV and FSTPDEV retain image data as it accumulates while DOSDEV and
      DOSDEV2 retain its associated data; these 4 partitions, therefore, must be formatted at the
      same time.
      To do so, select FSTDEV using the SST.
      Formatting of PDLDEV and DOSDEV2 takes place when the main power is turned on the next time.
      call for a tech to perform
