fi have a ir6570 about 11k copies in it now a days some times print or copy dosent come , i changed corona wires, reseated dimms ,even lower corona blocks , it will print for 1day or 2days after that it shows the smar problem , help me plz
ir6570 printing issue
Tags: None
Re: ir6570 printing issue
When you say sometimes print or copy doesn't come....I assume you mean blank or light copies. Which one is it, blank or light. Starting with the coronas was a good 1st step. Is the drum shaft screw tight? Intermittant problem with the laser shutter? Have you tried adding toner in service mode? Need more info to properly help you.sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.com -
plz helpComment
