Canon CLC 3200 Error Code E0005f4-0002
  • Justin_hr
    I need a help on Canon CLC-iR 3200 ErrorCode E0005f4-0002? Googled throught the internet, but nothing shows, Can somebody tell me what this errorcode is about?I believe it relates to the saddle finisher-N2 but apart from that I have no idea.
    Prompt response to this matter will be greatly appreciated, Thanks all.
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Re: Canon CLC 3200 Error Code E0005f4-0002
    Problem with the saddle stitching finisher stapler not reaching it's home position sensor. Your copier can run fine without the sorter if you want to disconnect it until the service guy arrives.
    • THUK
      • Jul 2008
      • 195
      hi it might booklet stapler unit pull it out and push it back in, switch copier off/on and see if it goes away.
      Or just pull out the finisher connector and run it as a copier.
