JA012 + E051-0002 on Canon iR 7105
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    Hello to all ...
    Another round another post .....
    I have a problem on a Canon iR 7105: during the warm-up, the machine gives me jam code A012 ...
    I open the duplex unit, where there is nothing, then reassembling, the machine gives me error code E051-0002.
    Have you ever had?
    Is there a solution?
    Thanks ..
  • charm5496
    • 2387
    Re: JA012 + E051-0002 on Canon iR 7105
    E051 use to be a false duplex jam on the IR-550 and was always a bad MSW5 switch casuing the problem. I'm sure it is the same since the 7105 uses the same basic structure as the 550
    • teckat
      • 16083
      E051 The horizontal registration HP detection has an error. PS18
      0002 == After the start of horizontal registration HP detection, the home position is not
      detected within 5 sec.
      If an error is detected in the course of horizontal registration HP detection at
      power-on, the machine will indicate the presence of a jam.
      • Ingranaggio_rotto
        • Oct 2010
        • 275
        But, there is no paper jam, as well as, once open and close the duplex unit, the error E051 appears, although the mechanism is working properly .....
        • teckat
          • 16083
          how do u know if horizontal registration HP is working/ when u still receive the E051
          removal /inspection/ testing / observation ????
          power-on,
          • watson
            • Sep 2009
            • 64
            Replace ps18 and you'll be happy.
