ir7200 very light copy
  • jiongpao
    • May 2009
    • 414
    Hi,
    Within these 3 days the machine came out a very light copy near blank but it not on every pages. On 500 pages there got 50-80 pages are near blank in stack in the middle of copying.
    I changed primary charging, transfer, pre-transfer and developer assy also no cure. Then i cleaned scanner mirrors nothing change. I dont know what else should i check and do. Please help
  • charm5496
    • 2387
    Re: ir7200 very light copy
    did you check your pre-exposure lamps to see if they are coming on?
    • nick55
      • Jun 2010
      • 51
      dont forget to clean connector terminal w/ alcohol. it might help
      • watson
        • Sep 2009
        • 64
        Your laser might be getting flaky and need replacing.
        • teckat
          • 16083
          Originally posted by jiongpao
          Hi,
          1-check developer bias AC/DC
          2-pre-exposure lamps/check connection
          Did u check PG5
          • bizhub1
            • Sep 2008
            • 230
            Had one do the same thing and it was the developer drive clutch.
            • gensys
              • Jan 2011
              • 323
              It can help you
              The Road will be Mastered by >>> the Going...
              • jiongpao
                • May 2009
                • 414
                Did u check PG5
                Sorry teckat how to check PG5? Actually im not sure what is PG5?
                Since we are having holiday for a week i might feed back slow in this thread after i try all the possibility solutions. But i need to wait them back on business then only i can go for 2nd try. Happy Holiday
                • charm5496
                  • 2387
                  service mode>copier>test>PG-Type to 5>hit (OK) and then hit start.
                  machine will output a test page with a grayscale on it.
                  • teckat
                    • 16083
                    READ PDF>>>>
                    • jiongpao
                      • May 2009
                      • 414
                      oO this is the easy check on hardware with this pdf
                      • mramlawi
                        • Jul 2011
                        • 838
                        iam facing same problem on same Model still dont know what to do more ,i changed two cylander original toner ,cleaned all the machine ,changed the laser still facing the same shet ,i pulled back the machine from the field and dont know what to do :S Why this Happen is there;s any bulltin about this Problem ?
                        thanks
                        Distinguished road makes you jewel in rough
                        • teckat
                          • 16083
                          thanks
                          post some copies-
                          is issue on copies & prints
                          what does your PG TEST Papers show
                          use the process of elimination procedure
                          write yours out/ then forward track on them > then back track <
                          • jiongpao
                            • May 2009
                            • 414
                            Hi guys the problem fixed when i cleaned the Developing clutch, CL4 and Developing cylinder deceleration clutch, CL20 at the back of machine without changing a new one, wondering why theres an oily around those clutchs. Tested 2 days and it was find till now but we need to monitor again for another few days.
