There have been cases reported where the rear screw that applies pressure between the fixing film and the pressure roller has become stripped. This creates uneven pressure which then causes the film to track improperly until it tears and generates a E007 code. Workaround is to replace the stripped screw with a longer screw or replace the fuser assembly. Also, do not overlook the screw hole in the metal making sure the threads are intact. fix1.jpgfix2.jpgfix3.jpgMAKE SURE U INSTALLED CORRECT PART IF U REPLACED UNIT Fuser Unit part number FM3-1293-020 is used for the iR 4570/3570/3045/3035 models. Fuser Unit part number FM3-7066-000 is used for the iR3245/3235/3230 models.
I have some Canon iR3235/45 modells with the same problem.
At the first time I change only the film (non OEM)
Second time I change the fixing film unit (FM3-7071) and the pressure roller (FC5-7207).
Sometimes it is not enough, in that case I have to change the whole assembly (FM3-7067)
But there are some machines in my practise that makes E007 error after 50000 copies after the changing of the original assy.
The worst machine of all, braked its first film at the counter of 15000.
I started to use my brain, spending a day with this problem.
I have cheated the right door switch, and switched on the machine.
At the time of the initial rotation (maybe 5 sec) the shortened film walked from right to left rapidly.
I wanted to adjust the machine that way, to avoid walking.
The adjust of the front or rear pressure had no result.
The adjust of the front alignment plates unsuccessful.
The twist of the fixing assy from rear could stop walking.
With a modified rear alignment plate the shortened film could staying on the rear during some motor test from the service mode. DSC00512.JPG
On the plate I have made 3 new holes as you can see on the picture above.
To tell the truth I have not enough experience (1 month) with this modifying to say it can solve the problem.
I have ir 3235, i change three fixing film n sensor but still give error 007 am stack In this
please help
READ THIS PDF>>>Measure to Prevent Displacement, Breakage of the Fixing Film and E007-0000 E007---iR3225 Series--TP09.pdf
There have been cases reported where the rear screw that applies pressure between the fixing film and the pressure roller has become stripped. This creates uneven pressure which then causes the film to track improperly until it tears and generates a E007 code. Workaround is to replace the stripped screw with a longer screw or replace the fuser assembly. Also, do not overlook the screw hole in the metal making sure the threads are intact. MAKE SURE U INSTALLED CORRECT PART IF U REPLACED UNIT Fuser Unit part number FM3-1293-020 is used for the iR 4570/3570/3045/3035 models. Fuser Unit part number FM3-7066-000 is used for the iR3245/3235/3230 models.
3 years ago it was a great problem.
The worst case was a 3235 which teared its film at counter 30.000
At first we changed only the film to non OEM.
After 1000 copies it went wrong.
Then we changed the film unit.
After 10000 it teared.
Then we changed the fixing unit ,and after 10000 page the film teared again.
Then I started a test with a 2cm shortened film in a coverless fixing unit.
I pulled it backwards and started a machine with cheated doorswitch.
During the initial rotation the film moved to front.
With my modificated back console the film remains on the back.
In the last 3 years I made more than 20 modifications and they works.
Metal plates are perfectly balanced, back screws are not stripped.
New film (oem), new pressure roller + bushing + everything.
Alignment plates are perfectly aligned in the machine.
I kept an eye for like 4-500 pages it was ok.
After 20.000 copies it tears at the front. WTF.....
Customer's color is RED like Popeye after eating spinach @@@
I did cut off the film, cheated the door and watched the moving forward.
I did (on purpose) release pressure on the back screw - than added pressure on back screw.
The result is always the same. The film moves forward.
I am afraid to do that back side modification on the body of the machine...on the other hand don't know what else to do.
I am afraid that if I order new fixing unit - it might behave the same.
Until now I made more than 20 modificated console, and maybe 1 doesn't solved the problem.
If the fixing unit with this modification became noisy you have to pull out on the back side a bit, to increase the distance of the drive and driven gears.
I used a 2,5 and after a 3,5 mm drill bit, with a drill stand.
On the other hand, you have nothing to loose, this is a reversible process.
