IRC ADV5051 Series Pinouts needed
  • mikeadel
    • Sep 2009
    • 12
    [Electrical] IRC ADV5051 Series Pinouts needed
    I need to know the Pinouts for J1026 on main controller 1. This is the where the interface kit A1 would plug into if you were installing a third party device, such as a card reader. Its a 9 pin connector and need the enable/disabled pins, copy count pulse pins etc. Thanks
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4999
    Re: IRC ADV5051 Series Pinouts needed
    • mikeadel
      • Sep 2009
      • 12
      Thanks, But I already know where J1026 is, What I need is the PINOUTS, ie what each pin on J1026, Enable/disable pin, copy pulse, etc.
      Originally posted by zoraldinho
      [ATTACH=CONFIG]14074[/ATTACH]
      • zoraldinho
        • Mar 2008
        • 4999
        What kind of issue do you have exactly?
        Try with diagram.....ira_c5051_series-gtc-gcd.pdf
        • mikeadel
          • Sep 2009
          • 12
          The PINOUTS are not in the wiring Diagram. all it shows is the Connector. I need to connect a third party card reader to J1026. The card reader has an *Enable (Normally Open) of relay *Enable (Common) of relay
          *Enable (Normally Closed of Relay *A Copy Pulse - * A copy Pulse +*
          • charm5496
            • 2387
            this machine has a copy control interface kit A1 to interface with third party devices
