J0208 in Canon iR 1020
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    Hi!
    I have an annoying problem on Canon iR 1020 ...
    The machine has just 3,000 copies and has frequently Jam 0208!
    In practice, does not separate well the first sheet from the second ...
    Suggestions?
    Thank you!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5011
    Re: J0208 in Canon iR 1020
    Inspect cassette pick up and reg.sensor SR 11.
    • Ingranaggio_rotto
      • Oct 2010
      • 275
      Already done ... No positive result .....
      • teckat
        • 16083
        Originally posted by Ingranaggio_rotto
        Hi!
        Suggestions?
        Thank you!
        try re-seating all connections on the Relay PCB
        add an extra wrap to the spring for SR11
        try replacing the SL2 solenoid
        also do this adjustment---------------------
        Widen both the front and rear Cassette side guides all the way.
        Remove paper.
        Then remove both front and rear tabs on the right side to remove the black cassette paper support.
        Note: Do not lose the three springs.
        Next loosen both front and rear cassette side guide screws. Push outward 1-2 mm then tighten screws.
        Fit the three springs on the lower cassette.
        Then install the cassette paper support in tabs. Add paper and test.
        • Ingranaggio_rotto
          • Oct 2010
          • 275
          I'll try ! Thank you !
