imagePASS A1
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    imagePASS A1
    Hi! (again, and I'm done for tonight)
    Bizarre question: can I print an old Mac with System 9.3 with the imagePASS A1?
    Without using the CWS ...
    Thank you!
  • charm5496
    • 2387
    Re: imagePASS A1
    I cant find any information saying that it is supported and I haven't run into anything that old in a really long time. have you tried connecting it at all?
    • Ingranaggio_rotto
      • Oct 2010
      • 275
      Re: imagePASS A1
      I connected the old MAC via Appletalk ...
      And appear in the print queue .... But without drivers the customer can't print....
      • teckat
        • 16083
        Re: imagePASS A1
        Thank you!
        NO-------------------------
        21 Century
        TP11.pdf
        Release of patch 1-1ASO3Y to enable Direct Mobile Printing support on the imagePASS-A1 V1.01.
        patch file will provide the Direct Mobile Printing functionality that will enable you to directly print to the
        Fiery imagePASS-A1 controller from iOS mobile devices, such as iPad, iPod Touch and iPhone via a wireless
        network.
        To use Direct Mobile Printing, you must:
        • Observe the minimum system requirements for your mobile device.
        • Enable Fiery print controller Setup options in Configure.
        • Make sure your Fiery print controller and the mobile device are on the same wireless network.
        Supported Fiery Controllers:
        • imagePASS-A1 V1.01
        Required Environments:
        -Apple iOS 4.2 or later is required for the following iOS mobile devices:
        • iPad
        • iPhone (3GS, 4G)
        • iPod touch (3rd generation or later)
        -imagePASS-A1 v1.01 with the patch file 1-1ASO3Y installed.
        -Wireless network environment
        • IEEE802.11- compliant wireless network router, which can communicate with iOS mobile
        devices, is required.
        • iOS mobile devices and the Fiery controller must be in the same wireless network subnet
        environment.
        • Ingranaggio_rotto
          • Oct 2010
          • 275
          Re: imagePASS A1
          Thanks....
