Decurling unit on iRC-ADV 9070.
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    Back here with a strange question ...
    I installed a Canon iRC-ADV 9070 without finisher ...
    But the machine does not detect the unit decurling .....
    It's normal?
    And then I must install the finisher in order to recognize the unit ?
    Thank you.
  • vigour
    • Aug 2010
    • 1038
    Re: Decurling unit on iRC-ADV 9070.
    you need an extra kit ( COPY TRAY P1 ) with a fan and exit tray.
    decurler is not used.
    you cannot make copies with decurler ONLY ( no finisher) if the system software is below a certain version.
    upgrade system anyway to latest.
    • Ingranaggio_rotto
      • Oct 2010
      • 275
      Interesting! May I know which system release?
      Thank you!
      • vigour
        • Aug 2010
        • 1038
        Just put the latest firmware you have.
        I tried testing copies on the first ones I installed before putting the finisher on and I would get a close door message, then later by accident I saw others without that message so I guessed firmware version. I always upgrade firmware as I install them, so I do not remember what version shows the close door message. It could be version 7 or something like that.
        • Ingranaggio_rotto
          • Oct 2010
          • 275
          Ok ....I will check ...
          Ah! But you can also make use of function decurling?
          • vigour
            • Aug 2010
            • 1038
            I am not sure what you are trying to do, so her is the complete version.
            If your custumer does not want a finisher, you cannot use the decurler unless you are going to drop the copies in a box or make your own exit tray.
            The plan is to attach a Copy Tray P1 to the engine.The Kit comes with a fan which goes in the exit door, to keep the paper on the tray.
            If you have a finisher, upgrade the system software and all will be well.
            If your version is very low go to single, and upgrade your finisher only first, or you will get an e-code.
            • Ingranaggio_rotto
              • Oct 2010
              • 275
              Ok.....Thank you !
