IMAGE PRESS C1
  • luisperu
    IMAGE PRESS C1
    Buenas tardes:
    Es posible manipular el contador de impresiones de una IMAGE PRESS C1 ? GRACIAS.
  • teckat
    • 16083
    Re: IMAGE PRESS C1
    Originally posted by luisperu
    Buenas tardes:
    Good afternoon:
    You can manipulate the counter IMAGE PRESS impressions of a C1? THANKS.
    you mean cheat the counter to fool someone
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5017
      Re: IMAGE PRESS C1
      • HELIO240
        • Jan 2011
        • 137
        Re: IMAGE PRESS C1
        Buenas tardes:
        Course, but since you are the engineer who designed the software, otherwise not.
        Now that fool you because someone, this is not correct.
        • its_just_a_copier
          • May 2011
          • 132
          Re: IMAGE PRESS C1
          Buenas tardes:
          Si se puede!
          Cambiar la configuracion de COPIER/OPTION/USER/COUNTER1 ~ 6 A
          en el valor deseado de acuerdo con el manual de servicio
          (hay 1,000 posibilidades diferentes)
          • teckat
            • 16083
            Re: IMAGE PRESS C1
            Originally posted by its_just_a_copier
            Si se puede!
            No se puede cambiar Total 101 CONTADOR
            You can not change TOTAL 101 COUNTER
            • its_just_a_copier
              • May 2011
              • 132
              Re: IMAGE PRESS C1
              yep, same with all Canon machines Boss.
