How can i set up auto receive fax
  • zestbe
    • Jan 2012
    • 3
    I have canon ir 5070 with fax option but could not set it up for receive fax any idea . Thanks in advance
  • vigour
    • Aug 2010
    • 1038
    Re: How can i set up auto receive fax
    all you have to do is connect it to a working phone line, with a telephone cable, and get someone to send you a fax, or you send someone a fax.
    press fax, tab punch in the receivers fax no, and press the green button.
    machines with universal send have the fax button after pressing the send tab
    • zestbe
      • Jan 2012
      • 3
      Thanks for rapid reply but my problem is that i cannot receive fax it rings but cannot receive even for ten ring it doesen;t go to receive mode
      • vigour
        • Aug 2010
        • 1038
        Did this fax ever work correctly or is it a recent change?
        Will it send?
        • zestbe
          • Jan 2012
          • 3
          it sends
          Will it send?
          • vigour
            • Aug 2010
            • 1038
            try service mode> fax> clear> all clear in case someone set it on manual.
            if it worked before, and now stopped working, you are looking at phone company problem,modem, ncu or main controller
            I had a case where the guy moved and Bell offered to redirect his faxes to a server, then he could login and print them. He still called for copier service , to make his fax receive like before.
