iR C3220 Setting a new image glass or Scanner, Help!!!
  • Smartmind
    • Aug 2011
    • 61
    [Misc] iR C3220 Setting a new image glass or Scanner, Help!!!
    Hello to all! well this is the issue, 2 month ago the old iR C3220 SCAN got broken, i call some body to setup the printer to use it just like a printer, now i have a used but in good conditions Scanner, This is the point, i already instaled the scan on its normal position, but i need help to set it up back on the system, display doesn't show the scanner funtion. Thanks for any help...
  • teckat
    • 16083
    Re: iR C3220 Setting a new image glass or Scanner, Help!!!
    If u have no error code--
    go in service mode--
    COPIER>OPTION>W/SCNR
    For copy models, sets whether scanner is present.
    The setting value takes effect after the main power switch is turned OFF/
    ON.
    Setting
    0: Printer model
    1: Model with scanner===set this to "1" power of /on printer
    u need to do your auto-gradation
    if glass was not replaced replaced -
    COPIER>ADJUST>CCD>W-PLT-X/Y/Z
    Use it to enter data for the standard white plate./
    COPIER>ADJUST>CCD>CCDU-RG/GB
    Use it to enter the image position correction value (dependent on the CCD unit).
    u need to put in settings below from original P PRINTS (hope u have them)
    COPIER>ADJUST>ADJ-XY>ADJ-X
    Use it to adjust the scanner leading edge position.
    COPIER>ADJUST>ADJ-XY>ADJ-Y
    Use it to adjust the CCD read start cell position.
    COPIER>ADJUST>ADJ-XY>ADJ-S
    Use it to enter an adjustment value for the scanner shading measurement
    point.
    Use it to enter white level data for the standard white plate.
    COPIER>ADJUST>CCD>W-PLT-Y
    COPIER>ADJUST>CCD>W-PLT-Z
    COPIER>ADJUST>CCD>CLF-R-RG
    Use it to enter a color displacement correction value for sub scanning direction.
    COPIER>ADJUST>CCD>CLF-R-GB
    COPIER>ADJUST>CCD>CL-R-RG
    COPIER>ADJUST>CCD>CL-R-GB
    COPIER>ADJUST>CCD>BW-R-RG
    COPIER>ADJUST>CCD>BW-R-GB
    COPIER>ADJUST>CCD>CCDU-GB
    COPIER>ADJUST>CCD>FCCDU-RG
    COPIER>ADJUST>CCD>FCCDU-GB
    • Smartmind
      • Aug 2011
      • 61
      Thanks a lot Teckat! i really appreciate your help.
