I have cleaned the patch sensor but still getting the problem listed above. Should I just replace the sensor?
Imagepress C1 Yellow toner spots and bands on no yellow
Tags: None
mailbiz
Re: Imagepress C1 Yellow toner spots and bands on no yellow
the image posted is a blockage of the between the blade and the the roller in the yellow developer assembly. You may be able to remove the blockage for a clean brush, but the developers will need to be changed very soon.Comment
mailbiz
The belt was just changed due to pit marks showing on copies. I will get to the developers and see if this corrects the problem. The banding shown in the copies does shift around on the copies.Comment
Definitely need to replace yellow developer.They are two different issues on.Damage on the cilinder and empty yellow starter.Read carefully the procedure for installing new developer!If it ain't broke, don't fix it
A picture is worth a thousand wordsComment
mailbiz
Have the toner issue fixed now when I place a LTR paper in the stack bypass and select the size I am adjust the guides but it will not accept the paper setting. Need Help.Comment
How do you fixed toner issue??If it ain't broke, don't fix it
Two possible solutions: First you must open and clean the impurities carefully revealing to lose.
the second option and you change the unit for another since the canon does not cover sales of developer unit which is located in the foam seal.
cheers.Comment
mailbiz
There is an impurity between the cylinder and the revealing of the same blade. Caused by deterioration of the foam cover developer unit, which loosens and falls within the unit.
cheers.
RegardsComment
Just folow the replacement precedure!Good luck.If it ain't broke, don't fix it
