6800 fixing assembly
  • acsolutions
    • Jun 2010
    • 519
    Hello, I am having a problem with the machine telling me, prepair to replace fixing assembly. I have reset counter for fixing rollers, thermistats, bearings etc. and goes away for awile then comes back. any suggestion would be appreciated.
  • charm5496
    • 2387
    Re: 6800 fixing assembly
    if I remeber correctly I think you need to change FXMSG-SW to a 0 then power cycle the machine. Are your fixing rollers getting flat spots on them at all?
    • ikon01
      • Apr 2011
      • 53
      charm is right,if your rollers have flats then swop them out.they will give you all sorts of problems.there is a secondary counter for the ufr under counter>misc>FX-UP-RL.
        • 16083
        To help prevent the premature deformation of the Upper Fuser Roller is to change the setting of FX-CROT in service mode. The default setting for FX-CROT is set to 0.
        Try Changing the setting from 0 to >> 3.
        Enter service mode level 1 (* 2 8 *), select Copier > Options > Body > FX-CROT and change setting accordingly.
        • charm5496
          • 2387
          I new you would remember teckat!!! way to go
          • acsolutions
            • Jun 2010
            • 519
            thanks the fxmsg did the trick. I also had adjusted the rotation value, thanks
            • charlzz_90
              • Sep 2015
              • 44
              i am having e0070-0001. what is the best solution?
                • 16083
                iR6800
                iR6870
                E070
                Sensor reflectors on the inside of the ITB become dirty and do not reflect the light properly from the home position sensors.
                Note* - If the equipment is not properly serviced, in regard to filters, the equipment filters can clog up and cause stray toner to build up in the ventilation area. If this occurs, there is a chance that HVT2 can become contaminated and copy quality issues will occur.
                Additionally, soiling the white ITB patch may also occur causing E070 error code.
                Solution :
                Clean the reflective surface inside the ITB or replace ITB.
                In regards to filters - Be sure ALL 6 Filters are replaced and/or cleaned at it's proper intervals. If ALL 6 filters are not addressed, poor ventilation will occur and toner can contaminate HVT2. If contamination of HVT2 happens replace HVT2.
                HVT2 = FM2-0528-000
                ITB = FC5-1658-000
                Also_
                Removed the tie wraps from the wire harness going to ITB HP sensor A (PS1).
                • charm5496
                  • 2387
                  Push this thing into a clearing packed with C4 and blow it up
                  • Wirestu
                    • Sep 2008
                    • 4
                    Hello Everyone,
                    I also am having the e070-01 error on a 5870. I had a new ITB so plopped it in with the existing belt which looked fine. Cleaned HP patches.
                    Same error.
                    Any ideas?
                    Thanks.
